Installing device packs on cucm 6- has it changed?
Answered Question
Jul 30th, 2008
  • Silver, 250 points or more
I recently uploaded a device pack on CUCM 6 to add a new phone type , I `ve done this before on 4.x and 5.x . On 4.x when you install the pack, you can instruct CUCM to install the new phone loads in to TFTP only but do not update the device defaults so you can manually control when you wish to update the phones, this was also the case on 5.x though it was not as obvious however on 6.x this seems to have disappeared. We have installed a device pack on two different CUCM 6.0 and on both occasions it updated all the phone loads in the device defaults without the option - has the process changed now or did I miss something ?
thanks
Correct Answer by Jaime Valencia about 8 years 12 months ago
6.x won't ask you for that, it will change firmware of device defaults if included in the DevPack
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Wed, 07/30/2008 - 05:19
  • Cisco Employee,
  • Hall of Fame,
    2011
java
iptuser55 Wed, 07/30/2008 - 06:01
So it is working as per , any idea why was it changed?
Jaime Valencia Wed, 07/30/2008 - 06:12
  • Cisco Employee,
  • Hall of Fame,
    2011
not really =(
probably has to do with the fact that now we're trying to lock down everything and give less options to avoid failures
java
