Site to Site VPN between ASA5510 and Linksys Befvp41
Jul 30th, 2008
I would like to setup a site to site VPN between ASA5510 and Linksys Befvp41. I have tried almost one month,it seems unsuccess. Any one have this experience? Please kindly advise. Thanks a lot.
dhananjoy chowdhury Wed, 07/30/2008 - 06:16
For configuration on ASA ,
For configuration on the Linksys router
The options on the VPN page may be a bit different depending on the firmware.
Make sure you have the same pre-shared key , Encryption, Authentication settings on both sides.
Also, on the Linksys box,
Under Remote Secure Group > select Subnet and then provide the LAN IP subnet that is behind the ASA.
Under Remote Security Gateway > select IP address and provide Public IP of the ASA box.
PFS > keep it disabled.
Hope this helps.
