Jaime Valencia Wed, 07/30/2008 - 05:20
  • Cisco Employee,
  • Hall of Fame,
    2011
it's in the same zip file where you get the IPC
CiscoIPCommunicatorAdminToolSetup.exe
java
if this helps, please rate
K_require Wed, 07/30/2008 - 06:02
Thanks. I need to know the purpose and functionality of this tool. Can you please provide any guide for it?
Jaime Valencia Wed, 07/30/2008 - 06:15
  • Cisco Employee,
  • Hall of Fame,
    2011
guess you have not downloaded and looked at any file because info is on the README.TXT
- To be launched on the TFTP server or Cisco Unified Communications
Manager Publisher. This tool will install the DirectoryWizard tool
for configuring the Quick Search and Dialing Rules features. It also
enables HTTP access for AutoUpdate and for IP Address auto-detection
in the network audio settings for unsupported VPN clients (getIP.asp).
refer to README.txt for any other info
java
K_require Wed, 07/30/2008 - 23:38
Yes. I got the same information from cisco site.
