AXL Request?
Answered Question
Jul 30th, 2008
I am trying to get my user information (e.g. PIN code) using AXL. I shall be very thankful for a sample AXL request for the same.
Best Regards,
M. Mudassir Saeed
Correct Answer by stephan.steiner about 8 years 6 months ago
You can't do that I'm afraid. Reading out credentials is not possible.. you can get the user but those fields are empty.
However, there's a call to check the user's pin (you supply a pin and userid, it tells you if it's correct or not).. the axl method is called doAuthenticateUser
Overall Rating: 5 (1 ratings)
Correct Answer
stephan.steiner Wed, 07/30/2008 - 22:22
m_mudassir_saeed Wed, 07/30/2008 - 22:29
Thank you very much Stephan, in fact I was looking for the same method "doAuthenticateUser". However, this is unavailable in CCM4.x.
