07-30-2008 05:16 AM - edited 03-03-2019 10:57 PM
Hi, i have 3750G switch, i want to upgrade ipservice ios on that switch, how can i upgrade and make sure that the switch will boot with the new ios.
Solved! Go to Solution.
07-30-2008 05:18 AM
Have you had a look at the config guide for 3750?
LR
07-30-2008 10:08 PM
First load the IOS in flash, its better to create a filder and copy the new IOS there using TFTP.
in 2nd step, change the boot path and save and restart.
Thats all you have to do. Let me know if there is any issue.
Usman
07-30-2008 05:18 AM
LR
07-30-2008 10:08 PM
Usman
