UC520 moh on autoattend script
Jul 30th, 2008
Hi to all,
I configured an autoattend on a UC520, I made the script wiht CUEeditor, it works fine, it have multi select ect...
But, when the caller select an option the calls are sent to a DN number (or huntgroup), so the phone ring and caller hear the free tone until somebody or voicemail answer.
Instead my client wants that after the selection the caller hear a MOH o msg prompt until somebody (the phone o huntgroup user) answer.
Is it possible to do, and How?
Thank a lot.
Augusto
Anonymous (not verified) Tue, 08/05/2008 - 08:57
We cannot do that and there is no option on CallManager express also in CallManager to do that. If you are thinking on it as a logical way it will cause a high system over head. If we want to configure the MOH, just configure it on the prompt, and the hunt group considers it as end user of the prompt.
