asa5505 vlans
Jul 30th, 2008
Dear sir,
i have tipical problem is i have two servers connected to unmanagble switch and from that switch to connected to one of of the port eth0/0 and i taken output eth0/1 and i conncted to my pc through the firewall i want to access my servers
through the firewall.
but my doubt is we r trying to access the servers through the intranet .
server ip:i have two servers connected to unmanagble switch and from that switch to connected to one of of the port eth0/0 and i taken output eth0/1 and i conncted to my pc through the firewall i want to access my servers
server ip address:129.9.15.4 and 129.9.15.5 gateway:129.9.1.1
this setup will work or not because iam accessing the firewall from outside.
plz any tips plz ,iam vrygreatfull to cisco fourms.
regards
srini
olivier.jessel Wed, 07/30/2008 - 06:48
If you access servers from outside, you can create a DMZ on your ASA 5505, by creating different vlan on interfaces. Default license is supporting up to 3 vlans I think, so only one DMZ interface is possible.
After, you just have to setup correct NAT and ACL settings to forward traffic from internet through the ASA to your servers (web, ssh or whatever you need).
Hope this helps you
dhanikonda Wed, 07/30/2008 - 08:12
Dear sir,
Thanks for ur reply and my communication betwwn the servers is intranet communications
all the servers r connected to unmanageble switch that switch to firewall firewall to p.c
these communication betwwen the servers through the firewall is intranet .
for this how can i configure the firewall.
Thanks&Regards
srini
