Server Shut Down
Jul 30th, 2008
We have a 7835 Server w/Call Manager and a 7835 Server w/Unity Connection. They are sitting on a table to be moved into racks. Is it just a matter of pressing the power button and moving them into the racks and pressing the button to bring them back up or do I need to do something else with their shut down??
Thank You!
thisisshanky Wed, 07/30/2008 - 06:18
I would suggest that you properly shut them down. Connect a monitor and keyboard , if its a windows box (for both platforms) then you can do that from Start-> Shutdown menu.
If its a linux box, you have to either do it from the web interface (OS administration) or from command line (Utils system shutdown).
Mojo1 Wed, 07/30/2008 - 06:23
Can I do one of the two below and which one is better to use?
Web Interface: Go to OS Administation-Settings-Version-Shutdown
Use PUTTY application and from the command line type Utils system shutdown?
