LMS upgrade - Problems with User Tracking
Answered Question
Jul 30th, 2008
i am having a problem where my user tracking dosnt pick up any users from my 6500 switches.
I was thinking about upgrading to LMS 3.1 but ist not available on the website, do I need to pay for this upgrade?
thansk
Marianne
Correct Answer by Joe Clarke about 8 years 11 months ago
That's what I though. The '@' is an illegal character for a Cisco community string. Remove this, perform a new Data Collection then a new UT acquisition, and you should be good to go.
Overall Rating: 5 (1 ratings)
Joe Clarke Wed, 07/30/2008 - 07:02
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
LMS 3.1 is available as a free upgrade for customers who have an SAS contract on LMS 3.0. The upgrade is delivered as a DVD. You can go to http://www.cisco.com/upgrade to request it, or contact your sales team.
That said, I do not think upgrading will solve your UT problem. What version of Campus Manager are you using now? Do these 6500 switches show up as green with the proper icon on the topology map?
ogormam2 Wed, 07/30/2008 - 07:10
Hi J,
iam using CM v5.0.3, the switches show up green, the icons are a green box with a green router on top the device type is C6509-ios.
thanks
Marianne
Joe Clarke Wed, 07/30/2008 - 08:13
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
There are no known bugs in CM 5.0.3 that would account for missing end host entries. What version of SNMP are you using with these 6500s?
ogormam2 Thu, 07/31/2008 - 00:36
Hi J,
here is an excert from the UT.log
2008/07/31 08:59:33 main VmpsAdminSMFGenerateTable: check arp: 00-13-21-fd-94-a3 10.225.97.4 EDC_Internal ISI_INT_FE
2008/07/31 08:59:33 main VmpsAdminSMFGenerateTable: Getting VTP DOMAIN from the router entry...
2008/07/31 08:59:33 main VmpsAdminSMFGenerateTable: NOT Getting VLAN Obj from the router entry as DOMAIN IS NULL...
2008/07/31 08:59:33 main VmpsAdminSMFGenerateTable: check arp: 00-1c-58-40-92-91 172.16.35.148 NULL_10.232.37.1(T) VLAN0150
2008/07/31 08:59:33 main VmpsAdminSMFGenerateTable: check arp: 00-03-ba-18-56-d5 10.225.250.40 EDC-DMZ ISI_LEGACY_EXT_FE
2008/07/31 08:59:33 main VmpsAdminSMFGenerateTable: check arp: 00-1e-4a-92-9c-3d 172.16.40.46 NULL_10.232.37.1(T) VLAN0190
2008/07/31 08:59:33 main VmpsAdminSMFGenerateTable: check arp: 00-17-a4-a9-01-c8 10.225.96.150 EDC_Internal ISI_INT_FE
ogormam2 Thu, 07/31/2008 - 04:05
HI J,
this UT.log narrows down the problem to one of the switches. the log mentiones something about not being able to find switch/cam table
2008/07/31 12:55:22 main VmpsAdminSMFGenerateTable: Device Found to UT Discovery 10.226.60.1
2008/07/31 12:55:22 main VmpsAdminSMFGenerateTable: using ARP table from 10.226.60.1
2008/07/31 12:55:22 main VmpsAdminSMFGenerateTable: using Bridge table from 10.226.60.1
2008/07/31 12:55:22 main VmpsAdminSMFGenerateTable: apply: No Switch Found/Error reading CAM tables
2008/07/31 12:55:22 main MESSAGE DBConnection: Created new Database connection [hashCode = 31475809]
End Time:2008/07/31 12:55:22
UT Discovery Success
2008/07/31 12:55:22 main VmpsAdminServiceModule: no file to import
ogormam2 Thu, 07/31/2008 - 08:17
HI J,
is there anything you an do to help me with this problem i have deleted all my devices and rediscovered them, all my 3750 type switches are working but im not getting UT info for any of my 6500 switches.
I have attached multiple UT logs and here is the last few lines frm the UT report.
thanks
Marianne
2008/07/31 16:53:02 main VmpsAdminSMFGenerateTable: apply: start
2008/07/31 16:53:02 main VmpsAdminSMFGenerateTable: apply: Phone Section completed
2008/07/31 16:53:02 main VmpsAdminSMFGenerateTable: Device Found to UT Discovery 10.226.60.1
2008/07/31 16:53:02 main VmpsAdminSMFGenerateTable: using ARP table from 10.226.60.1
2008/07/31 16:53:02 main VmpsAdminSMFGenerateTable: using Bridge table from 10.226.60.1
2008/07/31 16:53:02 main VmpsAdminSMFGenerateTable: apply: No Switch Found/Error reading CAM tables
2008/07/31 16:53:02 main MESSAGE DBConnection: Created new Database connection [hashCode = 23398687]
End Time:2008/07/31 16:53:02
2008/07/31 16:53:02 main VmpsAdminServiceModule: no file to import
2008/07/31 16:53:02 main VmpsAdminSMFGenerateTable: _subnetMap empty, reloading...
2008/07/31 16:53:02 main VmpsMajorDBUtil: Going to start a connection 0
2008/07/31 16:53:02 main VmpsMajorDBUtil: Going to start a raw connection a connection
2008/07/31 16:53:02 main VmpsMajorDBUtil: Getting DB.dsn property from ANIServer.properties
2008/07/31 16:53:02 main VmpsMajorDBUtil: Creating DB connection using CMF db service
2008/07/31 16:53:02 main VmpsMajorDBUtil: Creating Statement
2008/07/31 16:53:02 main VmpsMajorDBUtil: setting the fetch size
2008/07/31 16:53:02 main VmpsMajorDBUtil: Raw Connection started
2008/07/31 16:53:02 main VmpsMajorDBUtil: Loading generateSubnetMap......Done
2008/07/31 16:53:02 main VmpsAdminSMFGenerateTable: subnetMap# size after loaded from DB39
2008/07/31 16:53:02 main VmpsMajorDBUtil: Going to release connection
2008/07/31 16:53:02 main VmpsMajorDBUtil: Connection released
2008/07/31 16:53:02 main VmpsAdminSMFGenerateTable: summary: _macMap# 0 _ipMap# 0 subnetMap# 39 _subnetRouterMap# 0
2008/07/31 16:53:02 main UTMajorDiscovery: Subnet Map is written to the file
2008/07/31 16:53:02 main UTMajorDiscovery: Starting the message to serverterminated
2008/07/31 16:53:02 main UTMajorDiscovery: sending object toedcciscoworks
Joe Clarke Thu, 07/31/2008 - 08:53
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I wanted to know what version of SNMP you're using on this 6500. If looks like v1/v2c. If so, what is your SNMP community string?
ogormam2 Thu, 07/31/2008 - 11:30
Hi J,
I am using v1 (default not specified) with string [email protected]
thanks
M
Correct Answer
Joe Clarke Thu, 07/31/2008 - 13:02
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
ogormam2 Thu, 07/31/2008 - 13:06
You are joking, well thanks a million ill change that in the morning.
Ill repor back tomorrow,
again you very much
ogormam2 Tue, 08/05/2008 - 01:19
well i changed the strings and everything is working thank you very much
