How to implement 5 digits outgoing dialing?
Answered Question
Jul 30th, 2008
Call Manager 4.X
The customer have a lot of business contacts in DC area, so they want to speed the dialing. For example, most of their phone numbers in 202-313-XXXX range, so the user wants to dial 5-XXXX instead of 91-202-313-XXXX to reach their contacts.
How to configure the CallManager to apply this feature?
Thanks for your help!
Correct Answer by Ayodeji Okanlawon about 8 years 11 months ago
You can use translation patters to do this...
Go to CCMadmin>Route Plan.>xlation pattern.
Click add a new xlation pattern.
In the xlation patter field enter 5XXXX.
In the partition fied add the appripriate partiton, make sure that the css of user phones can reach this partition.
In the CSS field enter the apripriate CSS. Make sure the CSS has access to the partition of the Xlation pattern
scroll down to Called party xformations.
In the called party xformation mask..enter the full number eg 91202313XXXX
HTH, Pls rate useful posts
Overall Rating: 5 (1 ratings)
Jaime Valencia Wed, 07/30/2008 - 06:57
  • Cisco Employee,
  • Hall of Fame,
    2011
use translation patterns to modify 5.XXXX to 91-202-313-XXXX, fairly easy
java
if this helps, please rate
Correct Answer
Ayodeji Okanlawon Wed, 07/30/2008 - 07:13
  • Cisco Designated VIP,
    2017 IP Telephony
