ip phone firmware 8.3(5) for 7941
Jul 30th, 2008
Hello folks
yesterday night I tried to upgrade the firmware of all my 7941s, however they are now down because every single screen on the phone says "file not found sccp 41.8-3-5s"
I went to device defaults and the fimware version is correct.
I uploaded the file to the server through the os administrator>software update and then, I went to device defaults and the fields changed for the sccp phones 7941 and 7961, however they are not getting the file from the server.
please help
Jaime Valencia Wed, 07/30/2008 - 08:03
  • Cisco Employee,
  • Hall of Fame,
    2011
CUCM version?
please always mention that
java
if this helps, please rate
Jaime Valencia Wed, 07/30/2008 - 08:06
  • Cisco Employee,
  • Hall of Fame,
    2011
do you see the file in the TFTP server using the OS admin page??
java
cris_jimenez Wed, 07/30/2008 - 08:08
yes, that's what I did.
I uploaded the file using sftp and when it was successfully uploaded
Rob Huffman Wed, 07/30/2008 - 08:11
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Cris,
It sounds like the Firmware files for CCM 4.X versions may have been used here. I believe the files for CCM 6.X should be different like .cop
Can you check on this :)
Hope this helps!
Rob
cris_jimenez Wed, 07/30/2008 - 08:13
this is the file that I downloaded
cmterm-7941_7961-sccp.8-3-5.cop.sgn
Release Date: 30/Apr/2008
7941/7961 SCCP IP Phone load - Compatible CUCM Versions: 5.0(4)+
Rob Huffman Wed, 07/30/2008 - 08:39
  • Hall of Fame,
    Founding Member
Hi Cris,
The problem seems to lie in the naming of the file;
Can you try (on one phone - via Device>Phone> Firmware Load Information>
Phone Load Name
Changing this to SCCP41.8-3-5 (all CAPS no spaces no "s"
Reboot the phone in question and see what happens.
Rob
