ssl vpn with anyconnect
Jul 30th, 2008
I have ssl vpn with anyconnect working through an ASA. I need to change the default gateway that the client picks up after connecting, but can't find where to make the change. I can't even find where it is getting the current default gateway. Can anyone point me in the right direction?
Thank you.
1snelson Fri, 08/01/2008 - 07:01
That is what I would normally expect, however the default gateway that it is picking up is the address of my domain controller?
JORGE RODRIGUEZ Fri, 08/01/2008 - 08:25
  • Green, 3000 points or more
Agree with Andrew, DG is something you cannot change as it is virtualy assigned, unless indicated by Andrew.
Where is the tunnel terminated at inside, outside interfaces? I suspect you are probably using Webvpn Pool IP range scheme as an already used subnet from inside where your DC resides, if this is the case use a different private IP network for WebVPN tunnel group.
Jorge
1snelson Fri, 08/01/2008 - 08:53
The tunnel is terminated on the outside interface. I am using a webvpn ip pool that is part of our internal subnet. I need to be able to point to an internal gateway that can direct traffic to all parts of our internal network.
1snelson Fri, 08/01/2008 - 11:40
Thanks to both of you for pointing me in the right direction - it is working now.
