3550 Finding IP from Show mac-address
Jul 30th, 2008
So I perform a show mac-address and i see the mac address of all the devices attached and the port they are attached to, is there a way to find out what the ip's of the devices and which port they are attached to?
Thanks Greatly!
Overall Rating: 5 (2 ratings)
Collin Clark Wed, 07/30/2008 - 08:26
  • Purple, 4500 points or more
Go to the device that is the gateway for the subnet and do a show arp | inc [mac address]. You could also put an IP (or DHCP) on an interface on the particular vlan (on the 3550) and do the above command.
Hope that helps.
vtra Wed, 07/30/2008 - 08:37
Thanks, that worked. Some are come with blank responses even though the mac is there does that mean it's just an old entry?
Collin Clark Wed, 07/30/2008 - 08:50
Ping the broadcast address and that should repopulate the table.
vtra Wed, 07/30/2008 - 10:00
Thank you very much for your assistance, that did it!
