Configuration Question
Answered Question
Jul 30th, 2008
I want to setup a Call Center for one of my sites. Using two 7961 phones configured exactly the same (6500, *6500, **6500, ***6500, ****6500). All calls during business hours will be answered by a real person. After hours they will be forwarded to an outside answering service. How do I set this up?
Correct Answer by Rob Huffman about 8 years 8 months ago
Hi John,
It sounds like these are just Multiple Line appearances of 6500? If this is correct you can use either Call Forward All (controlled by the user) to the Answering Service or Time of Day Routing.
Check out this this excellent presentation on Time of Day Routing (it includes a great step by step and examples);
http://www.cisco.com/E-Learning/bulk/public/celc/CMToD/player.html
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Ayodeji Okanlawon Wed, 07/30/2008 - 08:53
  • Cisco Designated VIP,
    2017 IP Telephony
What does this mean...Do you mean the 7961 will have the same extension numbers?
Correct Answer
Rob Huffman Wed, 07/30/2008 - 08:59
  • Hall of Fame,
    Founding Member
    2017 IP Telephony, Unified Communications
Hi John,
Hope this helps!
Rob
