Email notification in Cisco IPS - how to configure
Answered Question
Jul 30th, 2008
Hi team,
How to configure email notification in Cisco IPs 4200.
I have the EV, and no cisco works.
Is it possible only thru cisco works ?
regards
Rajesh P
Correct Answer by pathgroup about 8 years 11 months ago
You can just click on Edit, Preferences, then check the enable email box. Type in your SMTP address, from address and recipient address. Choose what alerts you want to be notified (high, medium...). You can just tweak it as you need (changing the notification interal, content...etc). Hope this helps!
Overall Rating: 5 (1 ratings)
Farrukh Haroon Wed, 07/30/2008 - 18:12
  • Red, 2250 points or more
Email notifications are not supported on the IPS itself AFAIK. CiscoWorks does not work well for IPS, IME/IEV/CSM are the management applications for IPS boxes.
Farrukh
Sec IT Thu, 07/31/2008 - 00:21
Hi Farrukh,
I have event viewer installed. Can you tell me how to configure notifications thry EV.
regards
Rajesh
Correct Answer
pathgroup Fri, 08/01/2008 - 09:56
Sec IT Wed, 08/06/2008 - 01:44
Done.. i got it..
thanks..
Rajesh P
