07-30-2008 09:28 AM - edited 03-15-2019 12:18 PM
We are trying to setup SRST-CME. We are having issues with dial-peers and preference.
We have normal dial-peers that send calls to CallManager where it chops off the first digit for our 3 digit extensions. When I build the CME-SRST config on the router, the ephone-dns are taking a higher preference than the dial-peer to send the calls to CallManager. So, even when the CallManager is live, the DIDs are going to the CME and getting fast busys since no phones are registered.
Please help.
07-30-2008 04:20 PM
Please add the "no huntstop" on the ephone-dns.
HTH,
Chris
07-31-2008 04:04 AM
I found the answer. Thanks for the help though.
07-31-2008 06:06 AM
Whats the answer? Im curious
07-31-2008 06:31 AM
I created secondary extensions on the phones with their 4 digit DIDs and giving those secondary extensions a preferrnce of 5. I then created a dial peer with a $ at the end and preference of 1 pointing to CallManager. So when the CallMangager is up, it uses the preference 1 dial-peer. When it is down, the router uses the "virtual" CME dial-peer.
09-17-2008 10:21 AM
Could you post an example of this?
