Garbled text on console
jl1508246
Hello forum mates, I request your assistance to help troubleshoot a problem with garbled console text on a Cisco EMC MDS 9222i multiservice switch connected through a cyclades ACS48 console server.
This is what I see as my login prompt:
k4é§M:c¡ÓÓ¶·:ÿkLðEM
k4é§M:c¡ÓÓ¶·:ÿkLðEM
First of all, if I direct connect a rollover cable to the 9222i's console port, the text comes out clear. So thus, I believed it to be an issue with the console server port; the settings on the port where the MDS 9222i's console was connected are set to the classic 9600/8/None/1/off. I tried the patch cable in other ports with this same setting on this cyclades, and still received the garbled text, so the problem is following the cable. I swapped cables, used new cyclades dongles with no success. I then ran a direct line to the 9222i to rule out the patch panels in between source and destination, and got the same garbled text! In my environment, I have another cyclades with another MDS 9222i (who's console works fine through the cyclades); I tried swapping the patch cable from this known good 9222i console to the cyclades that is giving garbled text, and I saw the text come out clean. Then I tried the console on the 9222i I am troubleshooting into the known good cyclades port and saw the text garbled.
This is when I concluded it was an issue with the terminal emulation on the 9222i.
I tried comparing show terminal outputs from both 9222i's, but they were the same settings. Then there was more granular information such as show terminal internal info providing these two outputs:
Problem 9222i
EMC-Switch1# show terminal internal info
Process info:
State: R (running)
Tgid: 8866
Pid: 8866
PPid: 1
TracerPid: 0
Uid: 2002 2002 2002 2002
Gid: 503 503 503 503
FDSize: 256
Groups: 503
VmSize: 33424 kB
VmLck: 0 kB
VmRSS: 4264 kB
VmData: 636 kB
VmStk: 20 kB
VmExe: 416 kB
VmLib: 5828 kB
SigPnd: 0000000000000000
SigBlk: 0000000000000000
SigIgn: 8000000000310006
SigCgt: 0000000000087001
CapInh: 0000000000000000
CapPrm: 0000000000000000
CapEff: 0000000000000000
Memory limits:
core file size (blocks, -c) 48828
data seg size (kbytes, -d) 78125
file size (blocks, -f) unlimited
max locked memory (kbytes, -l) unlimited
max memory size (kbytes, -m) unlimited
open files (-n) 1024
pipe size (512 bytes, -p) 8
stack size (kbytes, -s) 8192
cpu time (seconds, -t) unlimited
max user processes (-u) 256
virtual memory (kbytes, -v) 78125
EMC-Switch1#
Known Good 9222i
EMC-Switch2# show terminal internal info
Process info:
State: R (running)
Tgid: 9499
Pid: 9499
PPid: 1
TracerPid: 0
FDSize: 256
Groups: 503
VmSize: 33420 kB
VmLck: 0 kB
VmRSS: 4032 kB
VmData: 636 kB
VmStk: 16 kB
VmExe: 416 kB
VmLib: 5828 kB
Memory limits:
EMC-Switch2#
I see a difference in the VmSize and VmRSS values. Would this be the cause of the garbled console through the cyclades?
thanks,
Joseph Lee
sbilgi
Level 5
Level 5
Use this troublshotting guide.
Cisco MDS 9000 Family Fabric Manager Configuration Guide, Release 3.x Troubleshooting Your Fabric .
http://www.cisco.com/en/US/docs/storage/san_switches/mds9000/sw/rel_3_x/configuration/guides/fm_3_4_x/tsfab.html
