FTP fail accross ASA-5550 - Parent flow is closed message
Jul 30th, 2008
I have a conection with a costumer to FTP data to a server, but the transfer fail after the "Parent flow is closed" message.
Anyone got any ideas?
Overall Rating: 5 (3 ratings)
dentt Wed, 07/30/2008 - 12:18
Do you have FTP inspection turned on?
dentt Thu, 07/31/2008 - 13:57
I would also issue a "clear asp drop" command in Priv-exec mode. Then start an FTP session and wait for the failure. Issue the "show asp drop" command and paste the output.
When the parent flow of a subordinating flow is closed, the subordinating flow is also closed. For example, an FTP data flow (subordinating flow) will be closed with this specific reason when its control flow (parent flow) is terminated. This reason is also given when a secondary flow (pin-hole) is closed by its controlling application. For example, when the BYE messaged is received, the SIP inspection engine (controlling application) will close the corresponding SIP RTP flows (secondary flow).
fjmendonca Tue, 08/05/2008 - 10:20
We are using Passive FTP.
The transmission starts and after 4400 bytes ends with the "Parent flow is closed" message.
robertson.michael Tue, 08/05/2008 - 12:01
  • Silver, 250 points or more
Try configuring a syslog server at level 6 to find out why the parent flow is being torn down. The message you want to watch out for is 302014. This message will give a specific reason for why the control channel is being torn down (i.e. resets, timeout, inspection, etc.) This will help identify the root cause of the issue.
-Mike
fjmendonca Thu, 08/07/2008 - 18:24
I do a "clear asp drop" command and start an FTP session and wait for the failure then I do "show asp drop" command.
The result is in the attached file.
I'm curious about the outcome of this thread. I'm experiencing a very similar issue wherein uploads to an Internet FTP server fail from a LAN client. What I find from the logs is that the FTP server, from the Outside interface, is denied FTP commands back to the LAN client; even though FTP Inspect is enabled. Can someone continue the explanation, and diagnostic process, for the show asp drop command?
suschoud Wed, 09/10/2008 - 08:00
  • Gold, 750 points or more
ALL YOU EVER WANTED TO KNOW ABOUT FTP AND ASA HANDLING FTP :
Various FTP forms:
1) Normal FTP
2) SFTP - SSH File Transfer Protocol
3) FTPS - FTP over SSL
i> Implicit FTPS
ii> Explicit FTPS
//// It has been assumed that FTP inspection is disabled on ASA in
scenarios below. ////
Normal FTP:
File Transfer Protocol (FTP) is a network protocol used to transfer data
from one computer to another through a network, such as the Internet.
-> Inbound FTP Scenarios:
Server----I(ASA)O----client
a) Passive Client [####FAILS####]
Client connects to server's public IP on port 21, authenticates. After
this client enters passive mode using PASV command. When server receives
PASV command, it generates a message in which client is informed about
the port it needs to connect to for data transfer. However, server uses
its own private IP address in the communication and because firewall is
not doing FTP inspection, it will not modify/translate the payload to
the public IP of server. Hence, client receives private IP address of
the server and is unable to connect for data connection.
Solution: Enable FTP inspection.
b) Active Client [####WORKS####]
Client connects to server public IP on port 21, authenticates. Then
client sends a PORT command. Server calculates the port to which it
needs to connect to the client and initiates the connection to the port
from source-port TCP/20 (ftp-data). Outbound connection works fine
because, by default outbound traffic is permitted on ASA.
FTP Inspection required: NO.
-> Outbound FTP Scenarios:
client----I(ASA)O----Server
a) Active Client [####FAILS####]
client sends a PORT command. However, PORT command is being sent using
clients private IP address and because firewall is not doing FTP
inspection, it will not modify/translate the payload to the public IP of
server , server receives a Private IP address of the Client. Due to
this, server is unable to initiate data connection to the Client and FTP
fails.
b) Passive Client [####WORKS####]
Client connects to server public IP on port 21, authenticates. After
the port it needs to connect to for data transfer. Client calculates
this port and initiates a outbound connection on this new port and
establishes SSL connection for data transfer. As this is an outbound
connection, everything works fine.
Refer to following link for detailed explanation of Active/Passive FTP:
http://slacksite.com/other/ftp.html
check the next post..........
Thanks! I've read through each post and find that in the option b) Passive Client [####WORKS####] FTP Inspection Required: NO scenario this applies to my configuration. Since we have FTP Inspect enabled to allow Internet customers access to FTP servers inbound (NAT to servers on the Inside Interface), then our Pasv clients on the LAN should be able to access Internet based FTP servers and perform Uploads and downloads Ad Nauseum. However, since the Uploads and Downloads fail (for LAN based clients on the Inside Interface to Internet based FTP servers on the Outside interface) and logging shows “Parent flow is closed”, or “Deny TCP no connection” from the FTP server with “FIN ACK on the Outside interface”, or “Deny TCP no connection” to the FTP server with “ACK on the Inside Interface”. I have to believe that further diagnostics need to be performed.
Your last line in the last post states, “If the above does not resolve issue,check client and server...issue is there.........>>>” would further indicate a need to “discover” what is happening. Which is why I was curious how to use the clear asp drop to continue trouble shooting this issue to point me to either server or client for additional discovery.
Looking forward to your response.
suschoud Wed, 09/10/2008 - 09:16
could you post :
sh run policy-map
sh run class-map
sh run service-policy
command outputs.
Also,let me know what version you are running on asa ( will check for bugs accordingly. )
you won't find anything is asp drops as " f/w " did not drop these packets on it's own.
The server closed the conneciton.The child connections which remained were deleted as parent connection was closed.For outbound connecitons,it's the outside server which closes the conneciton.If this server is accessible from a location which is not behind ASA,we need to check ASA.Let me check the basics first,if needed,we'll delve into captures......
Sushil
My pleasure and Thank you!
*** show run policy-map ***
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect esmtp
inspect pptp
inspect http
inspect dns
inspect icmp
inspect icmp error
inspect ftp
*** show run class-map ***
class-map inspection_default
match default-inspection-traffic
*** show run service-policy ***
service-policy global_policy global
*** ASA Version ***
ASA - 8.0(4)
ASDM - 6.1(3)
suschoud Wed, 09/10/2008 - 09:42
The config. is perfect.
The s/w code u r running does not have any known issues.
You mentioned you saw " parent flow is closed " message in the syslogs.
Before this log appears,there would be a teardown connection message...something like :
Teardown TCP connection 278 for
WAN:x.x.x.x/1868 to STORE-SERVER:y.y.y.y/21 duration 0:02:04
bytes 345 TCP Reset-O
This message will essentially tell us why the the connection was closed...." parent flow " message is just a follow up message which tells that the major connection ( control conn. ) is closed and data channel is now closed too.
Please look for this teardown and let me know what you see at the end.In the example above, RESET-O , is at the end of message which essentially mean that device on outside (server) sent a reset-bit set packet.In your case,it could be anything....let's find that out and you would know who the culprit is.
On a side note,make sure that there are no dropped packets on asa interfaces involved in communication.Sometime,few lost packets in ftp exchanges can result in teared connections.
Sushil
Thank you for your assistance!
*** These show up before the "parent flow closed" message but no Reset-(X) ***
Teardown TCP connection 20440132 for Outside2_Current:External FTP Server/21 to Inside:Client Machine/1958 duration 0:02:39 bytes 488 TCP FINs
Teardown TCP connection 20436932 for Outside2_Current:External FTP Server/21 to Inside:Client Machine/1935 duration 0:00:24 bytes 478 TCP FINs
Teardown TCP connection 20434600 for Outside2_Current:External FTP Server/21 to Inside:Client Machine/1923 duration 0:00:22 bytes 469 TCP FINs
Teardown TCP connection 20432302 for Outside2_Current:External FTP Server/21 to Inside:Client Machine/1911 duration 0:00:23 bytes 472 TCP FINs
Teardown TCP connection 20431530 for Outside2_Current:External FTP Server/21 to Inside:Client Machine/1907 duration 0:00:25 bytes 470 TCP FINs
*** Then I occasionally see this: ***
Deny TCP (no connection) from Client Machine/1909 to External FTP Server/15423 flags ACK on interface Inside
*** and this: ***
Deny TCP (no connection) from Client Machine/1897 to External FTP Server/21 flags FIN ACK on interface Inside
I hope this helps! :)
Thanks for your help!
*** As a side note, not to stir things up, FTP to this server worked with the previous firewall in place, W _ _ _ _ G _ _ _ _. FTP has failed to this server since the ASA has been in place. ***
suschoud Wed, 09/10/2008 - 10:52
Ohhh.. :(
tcp fins would mean that both client and server negotiated to close the tcp connection.
It's a normal tcp close down sequence.So,I cannot really say whether it's the client or the server where the problem lies.
Are there any dropped packets ( crc,overruns,underruns,collisions etc. ) on ASA interfaces.
Also,can you capture the relevant packets:
Issue with communication between a client on inside interface and a server on outside interface.
Replace IP addresses appropriately-
access-list cpo permit ip host host
capture capo access-list cpo buffer 2000000 packet-length 1518 interface outside
access-list cpi permit ip host host
capture capi access-list cpi buffer 2000000 packet-length 1518 interface inside
SRC_IP : This is the original IP address of client from where request is being
generated
XSRC_IP : This is the translated IP address of the inside client. IP address to
which inside client is translated when going outbound.
DST_IP : This is the Destination IP address.
Alternatively, captures on both interfaces can be taken in a single capture file.
access-list cap permit ip host host
capture capio access-list cap buffer 2000000 packet-length 1518 interface outside interface inside
To download the captures:
using a maching with ASDM access-
https://interface_IP/capture/capo/pcap
--> save file as outside.cap
(Captures on outside interface)
https://interface_IP/capture/capi/pcap
--> save file as inside.cap
(Captures on inside interface)
https://interface_IP/capture/capio/pcap
--> save file as inout.cap
(Captures on inside and outside interface)
If ASDM is not available, captures can be sent to a TFTP server using following commands-
copy capture:capo tftp://x.x.x.x/outside.cap pcap
(Captures on outside interface of PIX, capture file will be saved as "outside.cap")
copy capture:capi tftp://x.x.x.x/inside.cap pcap
(Captures on outside interface of PIX, capture file will be saved as "inside.cap")
copy capture:capio tftp://x.x.x.x/inout.cap pcap
(Captures on inside and outside interface of PIX, capture file will be saved as "inout.cap")
x.x.x.x : IP address of TFTP server.
Sushil
suschoud Wed, 09/10/2008 - 08:01
SFTP - FTP over SSH:
SFTP (SSH File Transfer Protocol), sometimes called Secure File Transfer
Protocol is a network protocol that provides file transfer and
manipulation functionality over any reliable data stream. It is
typically used with version two of the SSH protocol (TCP port 22) to
provide secure file transfer.
SFTP is **not** FTP run over SSH, but rather a new protocol designed
from the ground up by the IETF SECSH working group. The protocol is not
yet an Internet standard.
Port used: 22(TCP)
Firewall Perspective of SFTP-
Now, this is a firewall friendly stuff, reason being, all communication
is happening over port 22 (TCP). Hence, depending on setup, don't need
to configure much on firewall-
Server inside, client outside, normally, need to have static mapping for
the server and open port 22 to the server's mapped IP for traffic to
flow through.
Client inside, server outside, just need to open outbound access and
client should be able to access SFTP server.
FTP Inspection required: NO (Not a FTP protocol).
....contd. in the next post....
FTPS - FTP over SSL:
FTPS (S after FTP) is a super-set of the same FTP protocol, as it allows
for encryption of the connection over an SSL/TLS encrypted socket. There
are two modes this can be achieved-
i> Implicit FTPS
ii> Explicit FTPS
FTPS as a whole is not firewall friendly, refer to following scenarios
to understand why.
(I) Implicit FTPS-
In Implicit FTPS, basically it is a SSL encrypting socket wrapped around
the entire communication from the point of connection initiation. To
separate this from normal FTP, IFTPS was assigned a standard port
990(TCP), compared to normal FTP which uses 21(TCP). Note that this mode
is far less common than the explicit mode.
-> Inbound IFTPS Scenarios:
a) Inbound Implicit FTPS, Passive Client [####FAILS####]
Client connects to server's public IP on port 990, authenticates over
TLS (AUTH command). After authentication for data protection, client
uses command PROT. After this client enters passive mode using PASV
command. When server receives PASV command, it generates a message in
which client is informed about the port it needs to connect to for data
transfer. However, server uses its own private IP address in the
communication and because this goes over encrypted session, firewall
cannot modify/translate the payload to the public IP of server. Hence,
client receives private IP address of the server and is unable to
Inspection Required: No, will not help anyways.
Can we make this work through ASA: No (Opening all the ports to the
server will not make this work).
Workaround: Use Active client, see below.
b) Inbound Implicit FTPS, Active Client [####WORKS####]
Client connects to server public IP on port 990, authenticates over TLS
(AUTH). After authentication for data protection uses command PROT, then
client sends a PORT command over the encrypted session. Server
calculates the port to which it needs to connect to the client and
initiates the connection to the port from source-port TCP/989
(ftps-data), in normal FTP port TCP/20 (ftp-data). Outbound connection
works fine because, by default outbound traffic is permitted on ASA.
Inspection Required: No.
contd..........
suschoud Wed, 09/10/2008 - 08:03
-> Outbound IFTPS Scenarios:
a) Outbound Implicit FTPS, Active Client [####FAILS####]
TLS(AUTH). After authentication for data protection uses command PROT,
then client sends a PORT command over the encrypted session. However,
because this PORT command is being sent over encrypted session, server
receives a Private IP address of the Client. Due to this, server is
unable to initiate data connection to the Client and FTP fails.
b) Outbound Implicit FTPS, Passive Client [####WORKS####]
TLS(AUTH). After authentication for data protection uses command PROT.
After this client enters passive mode using PASV command. When server
receives PASV command, it generates a message in which client is
informed about the port it needs to connect to for data transfer. Client
calculates this port and initiates a outbound connection on this new
port and establishes SSL connection for data transfer. As this is an
outbound connection, everything works fine.
(II) Explicit FTPS-
Soon after FTPS was in use some smart people decided it would be best if
we could have an FTP server that could support unencrypted as well as
encrypted connections, and do it all over the same port. To accommodate
this the "explicit" FTPS protocol connection begins as a normal
unencrypted FTP session over FTP's standard port 21. The client then
explicitly informs the server that it wants to encrypt the connection by
sending an "AUTH TLS" command to the server. At that point the
FTPS-enabled server and the client begin the SSL or TLS handshake and
further communications happen encrypted. Note that most (if not all)
explicit FTPS servers can be optionally configured to require
encryption, so it will deny clients that attempt to transfer data
unencrypted. Often this can be configured on a user by user basis.
-> Inbound EFTPS Scenarios:
a) Inbound Explicit FTPS, Passive Client [####FAILS####]
Client connects to server public IP on port 21, authenticates over
However, server uses its own private IP address in the communication and
because this goes over encrypted session, firewall cannot
modify/translate the payload to the public IP of server. Hence, client
receives private IP address of the sever and is unable to connect for
data connection.
Can we make this work through ASA: Yes. See details below-
If client in this scenario are capable of using CCC (Clear channel
command), the FTP client connects to the server, negotiates a secure
connection, authenticates (sends user and password) and reverts back to
plaintext(control-channel). Next, enable FTP inspection. Now, when
server responds with the port client needs to connect to, firewall would
be able to intercept it and translate IP address in payload and also
open the connection accordingly.
Note: Not all FTP clients/servers might support CCC command.
Inspection Required: Yes, along with CCC command from client.
Workaround: See above.
b) Inbound Explicit FTPS, Active Client [####WORKS####]
TLS(AUTH). After authentication for protection uses command PROT, then
initiates the connection to the port from source-port 20 (ftp-data).
Outbound connection works fine because, by default outbound traffic is
permitted on ASA.
-> Outbound EFTPS Scenarios:
a) Outbound Explicit FTPS, Active Client [####FAILS####]
Client connects to server public IP on port 21, authenticates over TLS.
After authentication for protection uses command PROT P, then client
sends a PORT command over the encrypted session. However, because this
PORT command is being sent over encrypted session, server receives a
Private IP address of the Client. Due to this, server is unable to
Can we make this work through ASA: Yes, see explanation of workaround
for "Inbound Explicit FTPS, Passive Client"
Inspection Required: See "Inbound Explicit FTPS, Passive Client"
Workaround: See "Inbound Explicit FTPS, Passive Client"
b) Outbound Explicit FTPS, Passive Client [####WORKS####]
After authentication for protection uses command PROT P. After this
client enters passive mode using PASV command. When server receives PASV
command, it generates a message in which client is informed about the
port it needs to connect to for data transfer. Client calculates this
For more details about FTP AUTH, PROT, PBSZ, and CCC commands, refer to
following link:
http://tools.ietf.org/html/rfc2228
Sushil
