PRI ISDN Disconnect Error
Chad Stachowicz
Level 6
Level 6
All,
Basically completely intermittently we can answer calls successfull and the next fails. We can idivert toa PSTN voicemail system sometimes (out the same PRI's) sometimes we can't. It about 50/50 on everything working / not working. I have never seen anything like this before in my life. anyone any ideas? All primary-ni's...
debug..
*Jul 30 20:16:00.095: ISDN Se1/0:23 Q931: RX <- SETUP pd = 8 callref = 0x001D
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Facility i = 0x9F8B0100A10F02010106072A8648CE1500040A0100
Protocol Profile = Networking Extensions
0xA10F02010106072A8648CE1500040A0100
Component = Invoke component
Invoke Id = 1
Operation = InformationFollowing (calling_name)
Name information in subsequent FACILITY message
Calling Party Number i = 0x2181, '4153586031'
Plan:ISDN, Type:National
Called Party Number i = 0x80, '1638'
Plan:Unknown, Type:Unknown
*Jul 30 20:16:00.103: ISDN Se1/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x80
1D
*Jul 30 20:16:00.355: ISDN Se1/0:23 Q931: TX -> ALERTING pd = 8 callref = 0x801
D
*Jul 30 20:16:00.863: ISDN Se1/0:23 Q931: RX <- FACILITY pd = 8 callref = 0x001
D
Facility i = 0x9F8B0100A117020101020100800F544F5543484241534520555341202
0xA117020101020100800F544F55434842415345205553412020
Invoke Id = 1
Operation = CallingName
Name Presentation Allowed Extended
Name = TOUCHBASE USA
*Jul 30 20:16:22.623: ISDN Se1/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x8
01D
Cause i = 0x80BF - Service/option not available, unspecified
*Jul 30 20:16:22.647: ISDN Se1/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x001D
*Jul 30 20:16:22.647: ISDN Se1/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0
x801D
obviously Cause i = 0x80BF - Service/option not available, unspecified is the main clue..
Chad
Cheers,
Chad
6 Replies 6
Chad Stachowicz
Level 6
Level 6
Here is another debug from a failed call-forward to voicemail..
Standard = CCITT
Invoke Id = 1
*Jul 30 20:23:02.479: ISDN Se1/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x80
1E
*Jul 30 20:23:02.831: ISDN Se1/0:23 Q931: TX -> ALERTING pd = 8 callref = 0x801
E
*Jul 30 20:23:03.419: ISDN Se1/0:23 Q931: RX <- FACILITY pd = 8 callref = 0x001
E
Invoke Id = 1
*Jul 30 20:23:04.943: ISDN Se0/0/0:23 Q931: pak_private_number: Invalid type/pla
n 0x0 0x0 may be overriden; sw-type 13
*Jul 30 20:23:04.943: ISDN Se0/0/0:23 Q931: Applying typeplan for sw-type 0xD is
0x2 0x1, Called num 7202792979
*Jul 30 20:23:04.943: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8 callref = 0x00F5
Standard = CCITT
Called Party Number i = 0xA1, '7202792979'
Redirecting Number i = 0x000082, '3035661638'
*Jul 30 20:23:05.415: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x
80F5
*Jul 30 20:23:05.559: ISDN Se0/0/0:23 Q931: RX <- CONNECT pd = 8 callref = 0x80
F5
Progress Ind i = 0x8282 - Destination address is non-ISDN
*Jul 30 20:23:05.559: %ISDN-6-CONNECT: Interface Serial0/0/0:0 is now connected
to 7202792979 N/A
*Jul 30 20:23:05.563: ISDN Se0/0/0:23 Q931: TX -> CONNECT_ACK pd = 8 callref =
0x00F5
*Jul 30 20:23:05.623: %ISDN-6-CONNECT: Interface Serial0/0/0:0 is now connected
to 7202792979 N/A
*Jul 30 20:23:05.627: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0
x00F5
Cause i = 0x80AF - Resource unavailable, unspecified
*Jul 30 20:23:05.655: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x80
F5
*Jul 30 20:23:05.655: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref =
0x00F5
*Jul 30 20:23:11.327: ISDN Se1/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x8
01E
*Jul 30 20:23:11.355: ISDN Se1/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x001E
*Jul 30 20:23:11.355: ISDN Se1/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0
x801E
h323?? or MGCP??
if h323 do you have configured a voice class codec or codec under the dial-peer you hit??
if so, what codec are you sending? what codec is unity expecting??
this might be a simple codec issue or maybe not enough XCODER resources
java
if this helps, please rate
java
The Disc cause code for the callref 0x8 is BF.
This call was disconnected because the network or remote equipment cannot provide
the requested service option for an unspecified reason.
TRY THIS: This can be a subscription problem. Check with the service provider regarding
the services
javalenc,
Thanks so much for the response! The answer and I don't know why. was
no isdn outgoing display-ie on all the PRI's
All error's have gone away and its working like a champ. No transcoding BTW 100% g711 EVERYWHERE!
Cheers,
Chad
hmm the issue is definatly back, but not as extreme as it is when I turn on the diplay ie... The voicemail system is not unity its external. The key here is answering having a problem though, what would cause the phone to have a problem answering!?!?
Chad
I've same issue, also inserting command no diplay-ie outgoing.
Problem is major on fax calls inbound direction.
