The SSL VPN connection
Jul 30th, 2008
I have a VPN Concentrator Type 3020.
Sometimes it appears an error and is being dropped the connection. The message is: "The SSL VPN connection was terminated due to an IP forwarding table modification. A stable connection could not be re-established."
hadbou Tue, 08/05/2008 - 14:11
  • Bronze, 100 points or more
I think that a bug has been filed for this issue and the resoluiton for this issue is present in the SSL client 1.1.1.164.Upgrading to the latest SSL client 1.1.1.164 will resolve the issue.Do not included split tunneling routes in the configuration that conflict with
existing routes on the client PC.
carolinac Tue, 08/12/2008 - 07:19
How can i verify the version of the SSL client? and how can i upgrade it?
thanks
carolinac Tue, 08/12/2008 - 08:58
I just have download the ssl vpn client: sslclient-win-1.1.4.179.pkg
Now how can i make the clients update it?
