CUE does not recieve inbound CLID
I have a few SIP DID's on my CME (7.0, 2821) that are ringing either an extension or hunt group, which goes to CUE after 15 seconds. The message comes in correctly but CLID is never registered by CUE. Normally I should be able to see the inbound CLID of the sender's message in VoiceView but I do not - it's like it's not being passed to the CUE. What am I missing, or is this normal behaviour for incoming SIP calls? I can see sender ID when the message is from an internal extension.
Overall Rating: 5 (2 ratings)
Kenneth Mohammed Wed, 07/30/2008 - 13:27
  • Silver, 250 points or more
Do you have the command "voicemail callerid" in you CUE config?
jleon22 Wed, 07/30/2008 - 13:31
  • Bronze, 100 points or more
One place to check is in the CUE gui.
Go to Voicemail -> VM Configuration
Make sure "Play caller ID for external callers" is enabled.
Hope it helps.
