how to setup scep through https?
Jul 30th, 2008
I noticed that "enrollment url" command supports "https" and then tried to test it. I already enabled ssl support on my CA server(win2003 server). my ios configuration is:
2691_5(config)#crypto pki trustpoint pcserver
2691_5(ca-trustpoint)#show
enrollment mode ra
enrollment url https://hans-stress/certsrv/mscep/mscep.dll
ip-address 172.18.7.115
revocation-check crl
end
and then we I run "crypto pki authenticate pcserver" cmd, I got below problem:
2691_5(config)#crypto pki authenticate pcserver
% Error: failed to open file.
% Error in receiving Certificate Authority certificate: status = FAIL, cert length = 0
2691_5(config)#
Jul 30 14:00:09.909: CRYPTO_PKI: Can't find encryption certificate for trustpoint (pcserver)
Jul 30 14:00:09.913: CRYPTO_PKI: unlocked trustpoint pcserver, refcount is 0
Jul 30 14:00:09.973: CRYPTO_PKI: Adding peer certificate
Jul 30 14:00:10.013: CRYPTO_PKI: Added x509 peer certificate - (1419) bytes
Jul 30 14:00:10.013: CRYPTO_PKI: validation path has 1 certs
Jul 30 14:00:10.013: CRYPTO_PKI: Check for identical certs
Jul 30 14:00:10.013: CRYPTO_PKI: Create a list of suitable trustpoints
Jul 30 14:00:10.013: CRYPTO_PKI: Unable to locate cert record by issuername
Jul 30 14:00:10.013: CRYPTO_PKI: No trust point for cert issuer, looking up cert chain
Jul 30 14:00:10.013: CRYPTO_PKI: No suitable trustpoints found
Jul 30 14:00:10.013: CRYPTO_PKI: Certificate validation failed
Jul 30 14:00:10.013: CRYPTO_PKI: unlocked trustpoint pcserver, refcount is 0
Jul 30 14:03:56.045: crypto_engine: Generate public/private keypair
I'm thinking that's because IOS need to verify server's certificate firstly but fail. how can I setup IOS to not validate server's certificate at this time? or, I missed some other configuration?
Thanks a lot.
smahbub Tue, 08/05/2008 - 14:50
  • Silver, 250 points or more
To specify automatic enrollment (SCEP) to enroll with this trustpoint and to configure the enrollment URL, use the enrollment url command in crypto ca trustpoint configuration mode. To restore the default setting of the command, use the no form of the command.Router's with Dynamically Addressed Public
Address are not recommended to run Web VPN clients.
hansyin Tue, 08/05/2008 - 14:54
thanks. I'm just using "enrollment url" command. the problem is I hope to use "https url" instead of "http url". if using "https url", I have to tell IOS to accept peer's certificate firstly but I don't know how to do it.
