Catalyst express setup question
ciscomoron
I have a new Catalyst poe switch, and I used the express setup feature.
However, I noticed it didn't give me an option to enter a telnet user name.
Is there a way I can setup a user name?
garytayl
Level 3
Level 3
If you are talking about a Catalyst Express 500, there is no telnet access to those devices. GUI is the only option.
Q. Are there plans to add a CLI or Telnet to Cisco Catalyst Express 500 Series Switches?
A. No, there are no plans to add a CLI or Telnet to these switches.
Documented under:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6545/prod_qas0900aecd80322b09.html
It's for the 3560G.
Should I be able to specific a login and a password through telnet.
There is no username used, to set password:
From priviledged exec type: config t
line vty 0 4
password yourpassword
login
Replace yourpassword with the password you want to use
Carl,
There is no CLI with the switch he referred to in the OP.
