ISDN PRI
Answered Question
Jul 30th, 2008
Just want to check if this can be done.
I have a cisco router connected via ISDN PRI to a PBX.
router---ISDN PRI---PBX
I want to group the channels on the PRI.
Channels 1-15 will be specifically used for incoming calls to the pbx, and the rest of the channels to be used specifically for outgoing calls from the PBX.
Sample configs will be appreciated.
thanks,
Correct Answer by pcameron about 8 years 5 months ago
You can use pri trunk groups to do this -
controller E1 0/0/1
framing NO-CRC4
clock source internal
pri-group timeslots 1-31
trunk-group Inwards timeslots 1-15
trunk-group Outwards timeslots 17-31
dial-peer voice 1 pots
description - allow DID for PRI
incoming-called number .
port 0/0/1:15
direct-inward-dial
dial-peer voice 2 pots
description - outwards calls on TS 17-31
preference 1
destination-pattern 0
trunkgroup Outwards
dial-peer voice 3 pots
description - overflow dial peer
trunkgroup Inwards
Overall Rating: 5 (2 ratings)
Correct Answer
pcameron Thu, 07/31/2008 - 05:34
controller E1 0/0/1
framing NO-CRC4
port 0/0/1:15
direct-inward-dial
preference 1
trunkgroup Outwards
trunkgroup Inwards
