Problem with upgrading IOS on 4948
seducer666
I have 4948 switch with "12.2(31)SGA1" IOS (Conf reg is 0x2101). When I reload switch its boot without any errors.
Now I need to upgrade it to "12.2(31)SGA4".
My configuration is:
boot-start-marker
boot system flash cat4500-entservices-mz.122-31.SGA4.bin
boot-end-marker
When I reloading switch it gives out this error:
******** The system will autoboot now ********
config-register = 0x2102
Autobooting using BOOT variable specified file.....
Current BOOT file is --- cat4500-entservices-mz.122-31.SGA4.bin
Invalid filename cat4500-entservices-mz.122-31.SGA4.bin. It must begin with device name.
Type 'boot -help' for details.
The switch will automatically reboot now...
After three retries switch boots with old IOS.
How to solve this problem.
KT4948#sh ver
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-ENTSERVICES-M), Version 12.2(31)SGA1, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 26-Jan-07 14:48 by kellythw
Image text-base: 0x10000000, data-base: 0x1178C244
ROM: 12.2(20r)EW
Dagobah Revision 225, Swamp Revision 4
KT4948 uptime is 1 hour, 35 minutes
System returned to ROM by reload
System restarted at 08:01:35 MSD Thu Jul 31 2008
Running default software
cisco WS-C4948 (MPC8245) processor (revision 0) with 262144K bytes of memory.
Processor board ID FOX083805UU
MPC8245 CPU at 266Mhz, Fixed Module
Last reset from Reload
245 Virtual Ethernet interfaces
48 Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
KT4948#
Jon Marshall
Where is the image located eg.
if in flash
boot system flash flash:cat4500-entservices-mz.122-31.SGA4.bin
if on disk1 for example
boot system flash disk1:cat4500-entservices-mz.122-31.SGA4.bin
etc..
Jon
Ok I`am try to use "boot system flash flash:.." command.
Here my new config:
boot-start-marker
boot-end-marker
KT4948#sh bootvar
BOOT variable = flash:cat4500-entservices-mz.122-31.SGA4.bin,1;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
KT4948#sh bootflash
-#- ED ----type---- --crc--- -seek-- nlen -length- ---------date/time--------- name
1 .. image 92D5E1BE D1CBA8 38 13486888 Apr 23 2007 13:30:12 +04:00 cat4500-entservices-mz.122-31.SGA1.bin
2 .. image 88DEC3CE 1903388 29 12478304 May 5 2007 11:52:03 +04:00 cat4000-i5s-mz.122-25.EWA.bin
3 .. image 1EB1615F 25E3F44 38 13503292 Jul 18 2008 15:35:06 +04:00 cat4500-entservices-mz.122-31.SGA4.bin
But problem still present
Current BOOT file is --- flash:cat4500-entservices-mz.122-31.SGA4.bin
Invalid filename flash:cat4500-entservices-mz.122-31.SGA4.bin. It must begin with device name.
rommon 1 >
Hi there,
Mate, it looks like the boot variable is pointing at the flash: file system rather than the bootflash: file system.
try this:
boot system bootflash:cat4500-entservices-mz.122-31.SGA4.bin
hope that helps.. :)
Brad
