07-31-2008 01:24 AM
GSS along with CNR can offloading or replaces any DNS BIND. CNR is required for GSS to act as a full flesh DNS Server. I have following queries regarding CNR:
1. Can we configure other than A records like MX records in CNR?
2. URL having documentation to configure CNR?
Thanks & Regards,
Shahzad.
Solved! Go to Solution.
08-12-2008 10:20 AM
Shahzad
Name server value will be the value that you used while domain registration
for example for cisco.com the NS records are
cisco.com nameserver = ns2.cisco.com
cisco.com nameserver = ns1.cisco.com
ns2.cisco.com internet address = 64.102.255.44
ns1.cisco.com internet address = 128.107.241.185
so NS records will be ns1.cisco.com 128.107.241.185& ns2.cisco.com 64.102.255.44.
Syed Iftekhar Ahmed
07-31-2008 02:10 AM
HI Shahzad,
If you wants full DNS appliance or DHCP support or GSLB for other DNS record types, order the Cisco GSS DNS license (SF-GSS-DNSLIC) plus the Cisco Network Registrar software (CNR-6.3-BASE1K is the recommended base Cisco Network Registrar software for the Cisco GSS).
The Cisco GSS DNS software license allows you to load Cisco Network Registrar software onto your Cisco GSS 4492R, which transforms the Cisco GSS 4492R into a standards-compliant DNS and DHCP appliance that offers a very advanced feature set, including support for incremental zone transfers, dynamic updates, and notification. The Cisco Network Registrar DHCP server supports DHCP Safe Failover (redundant DHCP servers), dynamic DNS updates, DOCSIS cable modems, and integration with directory services using Lightweight Directory Access Protocol Version 3 (LDAPv3).
Note:
⢠Cisco Network Registrar software must be acquired separately. You must load Cisco Network Registrar Release 6.3 or higher on the Cisco GSS device to get the additional DNS and DHCP capabilities
⢠Cisco GSS Software Release 2.0(2) or higher must be loaded on the Cisco GSS device.
Kindly refer the following page for yor queries
Kind Regards.
Sachin Garg
07-31-2008 02:45 AM
Hi All,
Thanks Sachin for your reply.
We already have placed the order for the following licenses along with GSS:
SF-GSS-V2.0-K9
SF-GSS-DNSLIC=
CNR-SOFTWARE
CNR-6.3-BASE1K
CNR-6.3-ADD5K
Do we not need any in-house external DNS Server? Can we configure a full flesh DNS on CNR along with MX records etc.
I need URL explaining to configure CNR?
Shahzad.
07-31-2008 03:44 AM
Kindly find the url given below for
CNS feature's page
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/ciscoasu/nr/nr3-5/concepts/cg01.htm#wp2315
Cisco CNS Network Registrar User's Guide, 6.1
http://www.cisco.com/en/US/docs/net_mgmt/network_registrar/6.1/user/guide/nrug_1.html
Configuration Examples:
http://www.cisco.com/en/US/products/sw/netmgtsw/ps1982/prod_configuration_examples_list.html
Troubleshooting TechNotes
http://www.cisco.com/en/US/products/sw/netmgtsw/ps1982/prod_tech_notes_list.html
HOME page for guides:
http://www.cisco.com/en/US/products/sw/netmgtsw/ps1982/tsd_products_support_series_home.html
Command reference:
http://www.cisco.com/en/US/products/sw/netmgtsw/ps1982/prod_command_reference_list.html
Hope it will bring some useful information for your query.
take care.
And please do not hesitate any time you ifneed any further assistance please revert back.
sachin garg
07-31-2008 10:20 AM
Shahzad~
CNR is a fullfledge DNS Server. It can replace
any BIND implementation.In fact since its not open code its not vulnerable to BIND vulnerabilities.In addition the GSS has integrated DDOS mitigation software while BIND does not.
GSS (with CNR )can also be used as secondary DNS server to the BIND name servers.
GSS - CNR Installation
CNR configurations
http://cco.cisco.com/en/US/docs/net_mgmt/network_registrar/6.0/command/reference/cliref.html
Syed Iftekhar Ahmed
08-03-2008 11:18 PM
Thank you Sachin & Iftikhar,
It is confirmed by the Gurus that CNR is a fulfledge DNS Server. I have six SGG along with the license of CNR, so I do not need any other DNS Server. I can use these GSS as DNS Servers.
In this scenario, what will be the Name Server value while defining Zone or Domain (xyz.com)?
Thanks & Regards,
Shahzad.
08-12-2008 10:20 AM
Shahzad
Syed Iftekhar Ahmed
