07-31-2008 01:40 AM
I have configured http-cookie based stickiness. When i am executing "show sticky database sticky http-cookie <cookie-vlaue>" it is not showing anything. But when i am executing the command "show sticky database sticky" i am able to see the entries.
My question is that what is the cookie-value in the command mentioned above.
I have the Setcookie as shown below:
Set-Cookie: ciscoindia=R1187312271.
I have tried with R1187312271 as the cookie value and it isn't showing anything.
Please provide with your inputs.
07-31-2008 01:59 AM
Hi Nitesh,
First tell me on which device you have confred http-cookie.
On ACE device or CSS or GSS.
can be run on ACE
and
"show sticky database sticky" can be run on GSS /CSS.
After knowing the device your answer can be given more specifically.
Kind Regards,
Sachin Garg
07-31-2008 02:12 AM
Its ACE and "show sticky database sticky" can be run on ACE as well.
They are using A2(1.0) release.
07-31-2008 02:27 AM
can you send me the output of
show running-config sticky
07-31-2008 02:48 AM
07-31-2008 04:00 AM
Hi Nitesh,
The configuration you have send of the context to me does not contain any sticky configuration command.
Containing only probes, rserver, serverfarm, class-maps, policy maps.
Kindly send me the output for
#show sticky database sticky
and
#show running-config sticky
for the context containg sticky commands.
Also have you saved your configuration after adding http-cookie command.
Please let me know
best regards
sachin garg
07-31-2008 05:02 AM
Here are the outputs:
saec-scnpacesw01/Context-FE-Nonprod# show sticky database static
sticky group : sandbox.nokia.com-80
type : HTTP-COOKIE
timeout : 1440 timeout-activeconns : FALSE
sticky-entry rserver-instance time-to-expire flags
8299005317034422747 saesczq01:80 never -
sticky group : sandbox.nokia.com-443
type : HTTP-COOKIE
3225149268681361384 saesczq01:81 never -
sticky group : sandbox2.nokia.com-80
type : HTTP-COOKIE
10739917935203987419 saesczq01:80 never -
type : HTTP-COOKIE
15273335089781156206 saesczq02:80 never -
type : HTTP-COOKIE
2433051410394804892 saesczq02:81 never -
type : HTTP-COOKIE
17986435613451416461 saesczq02:80 never -
saec-scnpacesw01/Context-FE-Nonprod# show running-config sticky
Generating configuration....
sticky http-cookie kekkonen sandbox.nokia.com-443
cookie insert browser-expire
replicate sticky
serverfarm sandbox.nokia.com-443
sticky http-cookie koivisto sandbox.nokia.com-80
replicate sticky
serverfarm sandbox.nokia.com-80
sticky http-cookie nitesh sandbox2.nokia.com-80
replicate sticky
serverfarm sandbox2.nokia.com-80
