ACS on virtual server
Jul 31st, 2008
I want to install ACS 4.2 on Microsoft Windows 2003 inside Microsoft Virtual Server.
Is see that VMWare ESX is supported by Cisco. But no answer about VirtualServer.
Is anyone have idee about the Cisco support with Microsoft Virtal Server host ?
Overall Rating: 3 (1 ratings)
Jagdeep Gambhir Thu, 07/31/2008 - 13:33
Officially ACS is not tested and also not supported when running on Microsoft Virtual Server 2005.
ACS 4.1 is tested and supported when running under VMWare ESX 3.0.0.
But in couple of instance I have seen it working fine. So if you run into any issue TAC would not support.
Do rate helpful posts
