Keep loosing connectivity to ONS15454-E
Jul 31st, 2008
Hi there...
My computer keeps loosing the connection to the nodes in CTC, both the local node and the remote node.
I'm using JRE version 1.6.0_07 and CTC is version 8.5.1.
Anyone who has any ideas?
mchin345 Wed, 08/06/2008 - 13:04
  • Silver, 250 points or more
Might be communication interuption between the card and client. Reboot the device and try again it will resolve.
RADIM BERGER Mon, 08/11/2008 - 05:34
I had same problem ... in my case I used the following solution:
It's a network problem.
You have a firewall into your network.
You need to go from CTC on network parameters (provisioning --> network) and setup:
Enable SOKCS proxy
SOCKS proxy only.
This should work, but take care about your network topology.
E.G.: if you have some other host NOT 15454 connected to your network it's possible that you lost them.
So try it ... maybe, it will solve your problem ... Regards Radim
