RME - Change Audit window
tverhoeven
In RME change Audit Window there is a Message column. when I click on CONFIG_CHANGE title I get the following message.
DCMA0055: CM0036: The configuration file cannot be displayed as this could be a binary file.
Any ideas?
tony
Joe Clarke
Known issue for vlan.dat (VLAN) config changes. You cannot view the changes in this file. You can disable tracking the vlan.dat file for changes by checking the "Enable vlan Change Audit Filter" box under RME > Admin > Change Audit > Config Change Filter.
Joe Clarke
