Syslog not working
I am having problems with syslog. I can't get any mesg to show up. When I go to syslog collector status I have 0 accross the board.
I went to the syslog collector log and saw this
propFiled:/CSCOpx\MDC\tomcat\webapps\rme\WEB-INF\classes\com\cisco\nm\rmeng\csc\data\Collector.properties
SyslogCollector - [Thread: main] INFO , 31 Jul 2008 08:18:58,083, Logging System Initialized.
SyslogCollector - [Thread: main] INFO , 31 Jul 2008 08:18:58,083, System Initialized.
SyslogCollector - [Thread: main] WARN , 31 Jul 2008 08:19:05,036, Unable to resurrect connection to a subscriber.
SyslogCollector - [Thread: main] INFO , 31 Jul 2008 08:19:05,052, Service started...
SyslogCollector - [Thread: Thread-10] WARN , 31 Jul 2008 08:20:05,661, Unable to add monitor for netmgt01
prior to this a recived a TOMCAT error and then it purged all my logs.
help
Mike
If you're seeing a non-zero Forwarded count, then it's working.
6 Replies 6
Joe Clarke
If you're seeing 0, this means that SyslogCollector is not receiving any messages. Check your syslog.log file to make sure new messages are coming in. Make sure casuser has full control over this log file.
I deleted my subscribtion and then restarted cisco works. Once I restrted the server, then I statred seeing some syslog msgs coming in.
I went to the syslog collector file again and saw this.
SyslogCollector - [Thread: main] INFO , 31 Jul 2008 11:05:45,301, Logging System Initialized.
SyslogCollector - [Thread: main] INFO , 31 Jul 2008 11:05:45,301, System Initialized.
SyslogCollector - [Thread: main] WARN , 31 Jul 2008 11:05:52,567, Unable to resurrect connection to a subscriber.
SyslogCollector - [Thread: main] INFO , 31 Jul 2008 11:05:52,582, Service started...
SyslogCollector - [Thread: Thread-10] WARN , 31 Jul 2008 11:07:00,317, Unable to add monitor for netmgt01
IS it still not working correctly?
I have a casusers with full control
Mike
I am seeing 7 forwarded now.
Mike
I'm not getting rid of these 0s, but the Syslog.log file is bigger than 2Gig. :-(
Please start a new thread for your issue.
