asa 5510 - Routing failed (inside to dmz)
Answered Question
Jul 31st, 2008
Hi All,
I'am facing somehing not very hard but i cannot figure out how to solve it !
The actual configuration let me access :
- From Inside to internet
- From Outside to DMZ (one web server)
But i cannot access my web server from the inside interface, i get the following error :
"Routing failed to locate next hop for TCP from inside: to dmz:x.y.50.144/8080".
I get my main route from the DHCP server (ip address dhcp setroute). I don't know which static route but i guess, i have to add one in order solve it.
BTW, how do i check for my actual route with ASDM ?
Thanks for your kind help,
-sh run---------
: Saved
ASA Version 8.0(2)
hostname ciscoasa
domain-name asaname
interface Ethernet0/0
nameif inside
security-level 100
ip address
interface Ethernet0/1
nameif outside
security-level 0
interface Ethernet0/2
nameif dmz
security-level 50
ip address
interface Ethernet0/3
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
ip address
passwd xxx
ftp mode passive
clock timezone CEST 1
clock summer-time CEDT recurring last Sun Mar 2:00 last Sun Oct 3:00
dns server-group DefaultDNS
access-list outside_access_in extended permit tcp any interface outside
pager lines 24
logging enable
logging asdm informational
mtu management 1500
mtu inside 1500
mtu outside 1500
mtu dmz 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-602.bin
no asdm history enable
arp timeout 14400
global (outside) 200 interface
nat (inside) 200
static (dmz,outside) tcp interface 8080 8080 netmask
static (dmz,inside) x.y.50.144 netmask
static (inside,dmz) netmask
access-group outside_access_in in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable
http inside
http management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
no crypto isakmp nat-traversal
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
: end
Correct Answer by acomiskey about 8 years 2 months ago
Is x.y.50.144 the public address of the webserver? If so, I would do something like this.
Also, take the route out that you added.
Overall Rating: 4 (2 ratings)
acomiskey Thu, 07/31/2008 - 06:35
You need to add a route on the ASA to x.y.50.144.
route dmz x.y.50.144
scalacisco Thu, 07/31/2008 - 06:49
So i added "route dmz x.y.50.144 1"
Works better, i mean, now, the message is more informal but i still cannot access web server, the only infomation i have is "Built outbound TCP connection 1978 for dmz:x.y.50.144/8080 ( to inside: (" then "Teardown TCP connection 1978 for dmz:x.y.50.144/8080 to inside: duration 0:00:30 bytes 0 SYN Timeout".
The result of a show route give me that:
Gateway of last resort is v.w.50.254 to network
C x.y.50.0 is directly connected, outside
C is directly connected, dmz
C is directly connected, management
C is directly connected, inside
d* [1/0] via v.w.50.254, outside.
Correct Answer
acomiskey Thu, 07/31/2008 - 06:59
scalacisco Thu, 07/31/2008 - 07:12
Well ..... PEEEERFECT ! Yes, it is the web server public address. So i took out the route you gave me and added "static (dmz,inside) x.y.50.144 netmask "
Thank you !
I have "static (dmz,inside) x.y.50.144 netmask" in my conf, do i have to remove it ?
acomiskey Thu, 07/31/2008 - 07:17
Glad it worked. I would remove the other static.
Please rate posts you found helpful.
