SNMP ACL
Jul 31st, 2008
I have an ACL tied to our SNMP traps, and Im not sure if its working or not.
Currently I have setup:
access-list 21 permit xx.xx.xx.xx
snmp-server community {string} RO 21
Should this not by default assign the access list and deny everything else?
According to the logs, I am getting a ton of SNMP failures which I assumed shouldnt even hit the log because of the ACL.
Jul 24 12:07:25 MDT: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 85.29.8.182
Jul 24 12:07:28 MDT: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 85.29.8.182
Jul 24 12:07:31 MDT: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 85.29.8.182
Jul 24 12:07:35 MDT: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 85.29.8.182
Mark Yeates Thu, 07/31/2008 - 07:49
  • Gold, 750 points or more
Stuart,
The messages you are receiving aren't denies from the access list. It is a SNMP authentication failure. It appears that you have SNMP V3 setup. Make sure that the community and user name that are used in the SNMP request from the remote host have been configured on the router. Here is rather lengthy guide configuring SNMP on your device.
http://www.cisco.com/en/US/docs/ios/12_0t/12_0t3/feature/guide/Snmp3.html
Mark
rkhalil Thu, 07/31/2008 - 11:10
  • Bronze, 100 points or more
To sent traps to one host you need to configure
snmp-server trap-source Loopback1 >> optional
snmp-server host 10.200.100.100
10.200.100.100 is the ip of the server that's receive the traps
Raul
