static rule fail
using the attached config I can telnet to ports 951 & 952 on 2 different real IPs as configured and connecting to a listener on 192.168.200.2, a test machine connected directly to ASA
in order to test some of the real connections using the real internal IP and ports, I've added few access-list commands:
access-list outside_access_in extended permit icmp any interface outside
access-list outside_access_in extended permit tcp any host 63.x.y.26 eq 951
access-list outside_access_in extended permit tcp any host 63.x.y.27 eq 952
access-list outside_access_in extended permit tcp any host 63.x.y.25 eq lotusnotes
access-list outside_access_in extended permit tcp any host 63.x.y.26 eq smtp
access-list outside_access_in extended permit tcp any host 63.x.y.25 eq www
access-list outside_access_in extended permit tcp any host 63.x.y.20 eq https
access-list outside_access_in extended permit tcp any host 63.x.y.10 eq https
access-list outside_access_out extended permit ip any any
access-list inside_nat0_outside extended permit ip 192.168.200.0 255.255.255.0 172.16.20.0 255.255.255.0
access-list Split_T extended permit ip 192.168.200.0 255.255.255.0 172.16.20.0 255.255.255.0
I've also added matching static commands:
static (inside,outside) tcp interface 951 192.168.200.2 951 netmask 255.255.255.255
static (inside,outside) tcp 63.x.y.27 952 192.168.200.2 952 netmask 255.255.255.255
static (inside,outside) tcp 63.x.y.25 lotusnotes 192.168.200.12 lotusnotes netmask 255.255.255.255
static (inside,outside) tcp 63.x.y.26 smtp 192.168.200.6 smtp netmask 255.255.255.255
static (inside,outside) tcp 63.x.y.25 www 192.168.200.12 www netmask 255.255.255.255
static (inside,outside) tcp 63.x.y.20 https 192.168.42.200 https netmask 255.255.255.255
access-group outside_access_in in interface outside
adding those I can still telnet to ports 951\952
when I change the test machine to 192.168.200.12 and try to test port 80 or port 25 it is not connecting
I've checked ARP records (sh arp) on ASA and it does show 192.168.200.12
I can access ASA (telnet) and the internet from the test machine
any ideas?
I also had 2 problems configuring the static maps:
one of my services use a range of ports (200-210)
do I have to type in each port separately?
got the following error when I used the same internal IP\port combination for different real IPs:
ERROR: duplicate of existing static
TCP inside:192.168.42.200/443 to outside:63.x.y.20/443 netmask 255.255.255.255
acomiskey Thu, 07/31/2008 - 07:47
A configuration like this is not possible...
static (inside,outside) tcp 63.x.y.21 https 192.168.42.200 https netmask 255.255.255.255
acomiskey Thu, 07/31/2008 - 07:45
I would recommend you remove the following from your acl.
no access-list outside_access_out extended permit ip any any
Did you try a "clear xlate" after the change to .12?
I've been playing more and found something interesting:
when the test machine is changed to 192.168.200.12 port 1352 (lotusnotes) is accessible from out side
but port 80 not- it is going to my production firewall that uses a totally different IP:
HTTP/1.1 400 Bad Request ( The data is invalid. )
Via: 1.1 ProductionFirewall
Connection: close
Proxy-Connection: close
Pragma: no-cache
Cache-Control: no-cache
Content-Type: text/html
Content-Length: 1946
weird...
now I guess ports 80 & 443, just like smtp have their own different behavior
husycisco Thu, 07/31/2008 - 11:48
Hello Ofir,
I assume IIS (or what web server you are using) is affected due to IP change. Restarting the relevant IIS services after changing the IP in test machine would be helpful
Also try running "clear local-host all" in firewall after static changes
