Second T1 WIV
Richard Burts Thu, 07/31/2008 - 09:04
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Kaiser
You describe this as a second VWIC. Does that mean that you have already installed one of these cards in this router? If so the second card would be configured similar to the first card. If the first card required the card type to be configured then the second would also need this.
Some of the VWICs come as T1 only (or E1 only) and do not require the card type to be configured. Some VWICs come as T1/E1 and do require configuration of the card type. What specific card are you installing. This should help define whether you need to configure card type.
Rick
Richard Burts Thu, 07/31/2008 - 09:31
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Kaiser
I would assume that you would want to configure card type t1 1 0
Rick
