PIX/ASA outside ip address dhcp!
Jul 31st, 2008
I can't get through device to internet access using an ASA ver7.2 when using "ip address dhcp setroute". However it works when I use a PIX ver6.3!
Anyone come across this before or know how to get it to work through the ASA?
Below are the output from the "show route" and configs from each device:
PIX
pixfirewall#
pixfirewall# sh route
outside 0.0.0.0 0.0.0.0 192.168.1.1 1 DHCP static
inside 10.9.0.0 255.255.0.0 10.9.1.1 1 CONNECT static
outside 80.64.14.128 255.255.255.255 80.64.14.128 1 CONNECT static
pixfirewall#
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
hostname pixfirewall
domain-name ciscopix.com
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside dhcp setroute
ip address inside 10.9.1.1 255.255.0.0
ip audit info action alarm
ip audit attack action alarm
pdm location ISA2004 255.255.0.0 outside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
dhcpd address 10.9.1.3-10.9.1.33 inside
dhcpd lease 86400
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
END
ASA
ciscoasa# sh route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
* - candidate default, U - per-user static route, o - ODR
P - periodic downloaded static route
Gateway of last resort is 192.168.1.1 to network 0.0.0.0
C 10.9.0.0 255.255.0.0 is directly connected, inside
d* 0.0.0.0 0.0.0.0 [1/0] via 192.168.1.1, outside
ciscoasa#
ciscoasa#
ASA Version 7.2(4)
hostname ciscoasa
names
interface Ethernet0/0
nameif outside
security-level 0
interface Ethernet0/1
nameif inside
security-level 100
ip address 10.9.1.1 255.255.0.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
shutdown
no nameif
no security-level
no ip address
ftp mode passive
dns server-group DefaultDNS
domain-name default.domain.invalid
pager lines 24
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
http 10.9.0.0 255.255.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet 10.9.0.0 255.255.0.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
management-access inside
dhcpd lease 86400
dhcpd enable inside
username cisco password xxx encrypted privilege 15
Mark Yeates Thu, 07/31/2008 - 09:19
  • Gold, 750 points or more
Vince,
Try adding the "dhcpd auto_config outside interface inside" command. That is the only thing I see different from the working ASA's that I have configured in the past.
HTH,
Mark
vince.maxwell Thu, 07/31/2008 - 12:49
Hi Mark
I tried applying what you advised but it didn't make any difference. The DNS info was being pushed to the internal LAN clients.
The issue is a routing problem. The routing tables for the old PIX and the ASA generate different default/static routes!
Any other suggestions?
dentt Thu, 07/31/2008 - 14:02
Remove the dhcpd config from the outside interface.
vince.maxwell Thu, 07/31/2008 - 14:08
Hi the zero route is generated via the "setroute" keyword under the interface e0/0 "ip address dhcp setroute". If I remove that it doesn't have any route out at all!
The setup is via an DLink inline ADSL modem/router then into the ASA, with the Dlink having a LAN inteface address 192.168.1.1 which you see as the next hop. The ASA is picking up the public IP addressing but dosen't seem to be able to route anything, unlike the PIX which could.
