IOS image k9 and other client security issues
Mark Yeates Thu, 07/31/2008 - 13:39
  • Gold, 750 points or more
David,
The crypto runs strictly in the switch. Having the crypto IOS allows you to establish a secure connection to the switch Via SSH, or HTTPS. The crypto image does not perform encryption to your actual data.
HTH,
Mark
Mark Yeates Thu, 07/31/2008 - 13:49
You will need another router with a crypto IOS to create a VPN encrypted tunnel between the two routers. The switch is unable to perform VPN encryption.
Hi - Thanks for the info. I have another issue with my switch and lan setup. My client computer needs to send the data across our network to connect to a vendor router. He wants to have it encrypted. Do you have any suggestions? I am going to setup "protected ports"(no forwarding of info) and "port security"(port set to mac address). This isn't encryption. Thanks - Dave
Mark Yeates Thu, 07/31/2008 - 14:49
With your current setup I don't believe it can be done in a hardware configuration. Your best bet would be use a third party SSH tunneling software between the clients. I've never used this before but the only thing that came to mind.
HTH,
Mark
