MLPPP Question
Our provider cannot provide us an ethernet access connection for one of our existing site. He propose us to start with 2 x E1 in MLPPP.
I would like to know if there are some limitation using MLPPP?
Also, we have a CISCO2801 in that site, and plan to install a VWIC-2MFT-G703 card in it. Is MLPPP supported with that card/router?
Thank you,
Richard Burts Thu, 07/31/2008 - 14:26
Based on what you have told us so far I would think that MLPPP would be a good solution. MLPPP is certainly supported on the 2801 router. I have not used MLPPP on that particular card, but I would be confident that it does support MLPPP.
