AP 1250 Series - Recommended switches
Jul 31st, 2008
Good morning,
I am about to look into deploying the 1250's AP. I wish to get an idea on what would be the best switches to use that supports POE. I have started reading some documents but also wish to get other opinions.
We're using 3560E's to power our 1252 APs.
It's my understanding that with a 24-port E chassi sswitch, you can power up to 20 e-PoE devices, and up to 40 with a 48-port E chassis switch.
You do need to configure each switch interface with "power inline port maximum 20000" so that the AP can utilize increased power.
Scott Fella Mon, 08/04/2008 - 10:39
As long as the AP is getting the correct power from the switch, then you don't. If you look at the show cdp neighbor detail on the switchport, You can see if they AP and switch negotiated correctly.
