Incoming calls issue with GW running H.323
Jul 31st, 2008
Hello Folks,
I have a random problem I have a branch that have 4 FXO ports for incoming calls, configured as a PLAR. randomly when somebody calls to that branch on the caller end it will ring all the time and no phone will ring on the branch, the caller hangs up, calls for a 2nd time and the call goes through.
could you point me on the right direction
thanks
Marwan ALshawi Thu, 07/31/2008 - 18:47
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
why you dont do the following command under the FXO port
connection plar opx 4001
where 4001 one of internal directory numbers u can put whatever number u have internally
this will take the call directly to that number
rate if helpful
