Can Csico ACS do this?
Jul 31st, 2008
I have two IBM servers dual quad-core processors with 48GB RAM on each
server. I run VMWare ESX 3.5 on these IBM servers. On top of these
two ESX servers, I run about 96 instances of gentoo linux on each of
these IBM servers. I run TACACS+ tac_plus on each of these gentoo
linux systems. I have 96 customers and each customers have about 100+
cisco devices that I have to manage. I gave each customer two gentoo
linux servers for running TACACS+ with redudancies. This way, each
customer has their own tacacs+ servers. It has worked out pretty
well so far. The good things about this is that each customer has
their own AAA accounting log. No sharing log whatsoever. If customer
A demands AAA accounting logs for their device, I can provide customer
A aaa log within minutes.
Now I would like to consolidate everything with Cisco ACS. I know
that I can create separation for each customer with Network
Access Restrictions (NAR) but my question is this:
- Is there a way for me separate AAA accounting log for customer A,
customer B, C, ..Z? Is it possible?
Thanks.
Jagdeep Gambhir Fri, 08/01/2008 - 02:28
No, with acs it is not possible. You should go for Extraxi reporting software , that can present customized reports.
I'm not sure if it works on Linux. Dan from Extraxi should able to answer it.
www.extraxi.com
~JG
cisco24x7 Fri, 08/01/2008 - 03:18
Thanks Jgambhir. Is this something that Cisco
will add into ACS in the future? Cisco ACS
is really a good product but I am suprised
that it can not do this.
Jagdeep Gambhir Sat, 08/02/2008 - 06:09
Here you go..Presenting Cisco View
Purpose built and enhanced reporting engine to support Cisco Secure Access Control Server deployments
Cisco Secure Access Control System (ACS) View provides the highest level of reporting, alerting, and troubleshooting functions for Cisco Secure ACS deployments. Providing maximum visibility into configured policies and authentication and authorization activities across the network, Cisco Secure ACS View is the ideal solution for organizations that require the greatest levels of reporting and control.
Cisco Secure ACS View provides:
* Aggregate views of system activity at the transaction level for both network access and device administration
* Comprehensive view of network monitoring and planning, access problem detection and troubleshooting, and entitlement and compliance reporting
* Web-based user interface that simplifies generating and accessing predefined and custom reports
* Alert capabilities with thresholds and triggers on authentication activity for early detection of abnormal operation or trends
http://www.cisco.com/en/US/products/ps9302/index.html
~JG
Do rate helpful posts
