SIP and HSRP
Jul 31st, 2008
Hi Group,
i have 2 gateways running a SIP trunk with a SIP server. HSRP is configured on both for DATA failover. when the HSRP kicks in the SIP signalling stops working altough the 2 gateway have the same SIP configuration. how i can bind the SIP signalling to the HSRP? is there any alternative solution?
any help will be much appreciated.
hadbou Wed, 08/06/2008 - 13:06
SIP signaling and media paths can advertise the same source IP address on the gateway for certain applications, even if the paths used different addresses to reach the source. This eliminates confusion for firewall applications that, before to the use of binding, may have taken action on several different source address packets.
