Bandthwidth
Answered Question
Jul 31st, 2008
Hi, Currently three sites are connected with ASA 5505 through IP Sec STS VPN Tunnel. We have 1 MB link. Now I want to know that what is a minimum speed required for a single tunnel so that it works better. Does Cisco recommands this?? The Traffic data is not so much high on the tunnel, its normal. Thanks
Correct Answer by Farrukh Haroon about 8 years 8 months ago
There is no recommendation per se, it all depends on what you run 'inside' the tunnel.
Farrukh
Overall Rating: 5 (1 ratings)
Correct Answer
Farrukh Haroon Fri, 08/01/2008 - 04:20
  • Red, 2250 points or more
Farrukh
