ACS failover
Jul 31st, 2008
In our network we have implemented mac based authentication for wired users using acs. But i only have 1 ACS 1113 appliance but do have the s/w for ACS server.
Can i do some sorts of configuration in such a manner that if the acs appliance goes down users can still login into network by the acs server.
is it possible? if so then what would be the config into switches for this??
massimiliano.se... Thu, 07/31/2008 - 21:33
  • Silver, 250 points or more
In the configuration of your AAA server you have to set up another authentication server, that is you have to add the IP of the new server.
I hope this helps.
Best regards.
Massimiliano.
acharyr123 Fri, 08/01/2008 - 01:23
i know this Serafino. My question was: whether failover will take place between ACS appliance & ACS server????
Jagdeep Gambhir Sat, 08/02/2008 - 06:44
  • Red, 2250 points or more
Yes, that does not matter. Failover can also happen between acs and IAS but replication feature will not be available.
~JG
