Telco Speed Duplex Problem with ASA
Jul 31st, 2008
Hi.
I am having issue with a Firewall attached to our Telco router.
I have been told by the Telco (and had confirmed) that their customer facing interface is force set to 100MB/FULL DUPLEX.
However no matter what I set on the ASA (Auto/Auto or 100/FULL) I still see 100MB/HALF DUPLEX on the show interface command on the ASA. I am also seeing some minor collisions.
Please can someone advise on exactly what the show interface command in this case means; in particular what the bracketed (Half-duplex) refers to???
For information purposes the connection remains active with either setting.
Interface GigabitEthernet0/0 "outside", is up, line protocol is up
Hardware is i82546GB rev03, BW 1000 Mbps, DLY 10 usec
Full-duplex(Half-duplex), 100 Mbps(100 Mbps)
MAC address xxxx.xxxx.xxxx, MTU 1500
IP address xxx.xxx.xxx.xxx, subnet mask 255.255.255.224
954673 packets input, 1117595545 bytes, 0 no buffer
Received 20504 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
1 L2 decode drops
681592 packets output, 256981629 bytes, 0 underruns
0 output errors, 370 collisions, 13 interface resets
379 late collisions, 7333 deferred
0 input reset drops, 0 output reset drops
input queue (curr/max packets): hardware (0/14) software (0/0)
output queue (curr/max packets): hardware (0/15) software (0/0)
Farrukh Haroon Fri, 08/01/2008 - 05:48
In your case Full-duplex = configured duplex and Half-duplex=negotiated duplex. When auto-negotiation fails or is disabled, speed can be 'sensed' by the device but the devices fall back to half duplex as duplex is something that either has to be same on both ends or has to be negotiated.
It is apparent that your ISP has not properly configured his end. Double check that. Have a look at this:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a008009491c.shtml#speed
http://en.wikipedia.org/wiki/Autonegotiation#Duplex_mismatch
http://www.dell.com/content/topics/global.aspx/power/en/ps1q01_hernan?c=us&cs=555&l=en&s=biz
(scroll down to the duplex mismatching section)
Farrukh
