set mpls-label in MPLS VPN MP-EBGP multihop
Jul 31st, 2008
  • Gold, 750 points or more
I just want to know in MPLS VPN where you have MP-EBGP multihop session between PEs not ASBR... so when do we need to use set mpls-label to set the MPLS label... as we are using send-labels on ASBRs...
Actually I want to know in which case or scenario do we need to use route-map to set mpls-label?
regards
Devang Patel
lee.reade Thu, 07/31/2008 - 23:48
  • Silver, 250 points or more
You only need to use the set-mpls label when you are filtering the VPNV4 routes that you want to send to a VPNV4 BGP peer.
Ie, if you were filtering the routes via a route-map matching a prefix list, then you would put the set-mpls label in the route-map entry with the permit clause.
Ie.
route-map rmap deny 10
match ip address access-list 101
route-map rpmap permit 10
match ip address prefix filt
set-mpls label
LR
Harold Ritter Mon, 08/04/2008 - 12:29
  • Cisco Employee,
Devang,
"set mpls-label" is only useful with IPv4 + label, not with VPNv4. This command is usually configured on the ASBR to only send label for loopback addresses to the other AS.
devang_etcom Mon, 08/04/2008 - 20:30
Hritter,
SO does it means I will advertise only desire prefixes with the labels only right?
and what is use of match mpls-label on other hand... does it accept or redistribute prefix with only mpls label?
regards
Devang Patel
Harold Ritter Tue, 08/05/2008 - 05:01
  • Cisco Employee,
Devang,
VPNv4 includes a label per prefix. You can't change that.
With IPv4 + label though, it is possible to select which prefixes will have a label or not.
