isdnbri
Jul 31st, 2008
Dear sir,
iam having 2821 router in that we inistalled and configured isdnbri its working and iam getting the fallowing error
Jul 31 10:39:26.231: ISDN BR0/0/0 EVENT: process_rxstate: ces/callid 1/0x33 calltype 1 HOST_INCOMING_CALL
*Jul 31 10:39:26.235: ISDN BR0/0/0 EVENT: host_incoming_call: call_id 0x0033, Guid = C7F1B57B8030 bchan 0
*Jul 31 10:39:26.235: ISDN BR0/0/0 **ERROR**: host_incoming_call: DIALER ERROR 0x1: b channel 0, call id 0x33
*Jul 31 10:39:26.235: ISDN BR0/0/0 EVENT: process_rxstate: ces/callid 1/0x33 calltype 1 HOST_DISCONNECT_ACK
plz can i get what this eeor.
Thanks®ards
srini
lamav Fri, 08/01/2008 - 04:42
You probably have something misconfigured.
Check:
switch type
signalling
spids, if they apply
number you're dialing
etc.
Go to Ciscos website and read how you should be configured.
Richard Burts Fri, 08/01/2008 - 08:50
srini
Perhaps I am a bit confused. In the beginning of your post you seem to say that the BRI is working. But then you post error messages that show that it is not working. Is the BRI working for some calls but not for others? Or is it failing on all calls?
The suggestion from Victor to check on the Cisco website is worthwhile. If you check the website and still do not find an answer then I would suggest that it might be helpful if you would run debug isdn q931 and post the output from that when a call fails.
Rick
