asa 5510 - VPN Access
Aug 1st, 2008
Hi all,
I configured an ipsec vpn access with the ASDM wizard. The connection is fine, but i am unable to see anything, the only interface i can ping is the outside one.
Without VPN, i can LAN 2 WAN, LAN 2 DMZ and WAN 2 DMZ.
How can i have the same (access the LAN and do 'LAN 2 WAN' and 'LAN 2 DMZ' and also to the management interface) when i am connected throught VPN ?
Plz find in att my running conf.
Thanks in advance,
Best regards.
jjohnston1127 Thu, 08/07/2008 - 10:43
  • Silver, 250 points or more
Nat Traversal is disabled in your configuration. Often, that has been the problem of my VPN setups.
Run the command: crypto isakmp nat-t
