Interface configuration standardization through baseline templates in RME.
Aug 1st, 2008
I have been trying to deploy standard configuration on the routers for different models. While deploying the Global configurations commands are getting deployed properly. However, the interface configuration commands are returning errors. I have gone through the online help and used thr format mentioned in the help but it does not work.
PLease suggest.
Bhavesh
Joe Clarke Fri, 08/01/2008 - 08:50
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What version of RME are you using? What does your baseline template look like?
