08-01-2008 01:18 AM
On CSS11506, we are testing to use weblogic virtural machines as backend servers for load balancing. the four virtural machines are located on same physical machine, with same ip address, but different ports.
The configuration is:
service virtural1
ip address 10.1.1.10
protocal tcp
port 7021
active
service virtural2
protocal tcp
port 7022
active
service virtural3
protocal tcp
port 7023
active
service virtural4
protocal tcp
port 7024
active
content test-virtual-lb
vip address 10.3.1.10
protocal tcp
port 80
advanced-balance cookies
url "/mytest.mydomain/*"
add service virtural1
add service virtural2
add service virtural3
add service virtural4
active
it works but not stable; the stickness can not maintain properly. either user can not login or session be reset after login.
Could I get advice about this architecture, if it can be done?
If so, how do I do it?
Any comments will be appreciated
Thanks in advance
Solved! Go to Solution.
08-01-2008 02:01 AM
the sticky method you have chosen does not do what you expect.
The CSS can't learn dynamic cookies from servers.
You should use 'advanced-balance arrowpoint'.
This will create static cookies and the CSS will inject them in the server response.
Gilles.
08-01-2008 02:01 AM
Gilles.
